kev12
Message 1 of 2
BT Virus Protect
I am unable to download BT Virus Protect to my Laptop (Vista Home Premium 32 bit). I get an error message to update my Windows Service Pack, but this is not available on the Windows updates list. Does anyone know how to solve this problem.
1 REPLY 1
gg30340
Message 2 of 2
Re: BT Virus Protect
BT Virus Protect is compatible with Windows Vista but you must have Windows Service Pack installed.
You can get the service pack direct from Microsoft.
See link
https://www.microsoft.com/en-gb/download/details.aspx?id=30
I would however recommend that you either upgrade your computer or its operating system because as I'm sure you will know, Windows Vista is no longer supported by Microsoft and is becoming more and more  vulnerable to cyber threats. IE9 is also not supported and few other browsers are supported with it.
