Newbie
Message 1 of 3
BT WIFI app won't accept my bt email address is my bt id.
Hi
I have recently upgraded my mobile phone and downloaded the BT WIFI app, but when I input my login details and press log on I get this message. Screenshot_20200409-155900.png
If I press ok it just takes me back to the login screen.
With earlier phones I have had a similar message but with an option to ignore or go ahead anyway.
The email address is my BT ID and I do not really wish to change it. I have viewed posts with similar issues but not this one.
ps sorry about the size of insert.
2 REPLIES 2
Message 2 of 3
Re: BT WIFI app won't accept my bt email address is my bt id.
Enter the address as  @btinternet.com rather than @openworld.com. As an email address the 2 are interchangeable, as a username for BTID they are not.
Newbie
Message 3 of 3
It worked. Thanks for the help,I knew about the @btinternet alternate but never occurred to me to use it here.
