EJT1
Message 1 of 5
BT Wi-fi hotspot
I have broadband.  I use BT fon hotspot but this has disappeared from my Wi-fi when I’m mobile. BTwi-fi. has appeared as a hotspot option but it won’t allow me to connect yet I’m logged in.  Are the hotspots not working or is this just me in ealing.
4 REPLIES 4
imjolly
Message 2 of 5
Re: BT Wi-fi hotspot
if you are using BT hub can you connect to BTWIFI-FON broadcast from your hub?
EJT1
Message 3 of 5
Hello.  No I can’t connect to it from that
imjolly
Message 4 of 5
If using your mobile then I would 'forget' the wifi connection on your phone and then try and re-connect to BTWIFI- FON with you BTID  until you can connect to your own FON connection you will not connect when roaming
Tags (1)
EJT1
Message 5 of 5
Thanks imjolly!!!! I forgot the Wi-fi and reconnected as advised and it worked. Yeah! Thank you.
