Venger
Message 1 of 18
BT WiFi Google Safe Search
As BT failed to install my broadband and I have no idea when it will be connected I have had to use BTWiFi and BTWiFi with Fon which are extremely unreliable but when I do get connected I notice that when using Google search engine that Google SafeSearch is activated by default and cannot be turned off, why not?!
Anyone else noticed this?
17 REPLIES 17
Guru
Guru
Message 2 of 18
Re: BT WiFi Google Safe Search
I believe the BTWifi (BTOpenezone/BTFon) public wifi network forces Safe Search on to block any unwanted/indecent search results.
This is a feature offered to ISPs by Google and other providers.
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Venger
Message 3 of 18
Fair enough but the customer should have the right to turn it off!
Message 4 of 18
BT WiFi is a public service and has to be controlled following recent legislation just the same as a conventional broadband service has parental controls activated as default on them
Guru
Guru
Message 5 of 18
@Venger
It's only forced on BT's public Wifi network (ie BTWifi, BTOpenzone, BTFon), as this is a public service then I believe it's understandable for BT to apply more protection over it.
It's not forced on any BT residential or business broadband service.
Try a Search
Venger
Message 6 of 18
You didn't address my point that BT should make it possible for the customer to opt out of it!
Venger
Message 7 of 18
Yes but I'll say it yet again BT should make it possible for the customer to opt out of it!!
Message 8 of 18
you are not the customer the customer is the owner of the hub you are just piggybacking on another customer's connection
Message 9 of 18
See https://support.google.com/websearch/answer/510?source=gsearch&hl=en
Its just a cookie I believe.
Venger
Message 10 of 18
john46 if you don't have anything helpful to add then keep your condescending, patronizing opinons to yourself!
