Hayseed
Message 1 of 21
BT WiFi X
What is BT WiFi X? I can connect to Fon with no trouble but not X. I am a BT broadband customer using iPhone and iPad. I have looked at BT FAQ’s but there is no mention of X.
20 REPLIES 20
Dean007
Recognised Expert
Message 2 of 21
Re: BT WiFi X
Hi @Hayseed
BT Fon, Wifi X are all now BT Wifi. Wifi X used to be the way apple users could join the free wifi network.. now its Just BT Wifi.
BT Wifi Rebrand
imjolly
Message 3 of 21
Re: BT WiFi X
@Dean007
the hubs broadcast both BTWIFI-FON and also BTWIFI-X   the latter is specific to apple devices
even the newest hubs broadcast both
Dean007
Recognised Expert
Message 4 of 21
Re: BT WiFi X
@imjolly
learn something new everyday.  I have BT Wi-fi turned off so I didn’t notice.
I would suspect that X or Fon offer the same speed and coverage?
Paul_31
Message 5 of 21
Re: BT WiFi X
If you want to login to BTWiFi-X I think you need to install the profile on your iDevices.
You’ll need the BT WiFi app on your devices. Launch it and top right corner of the screen are thee dots. Tap on those and then ‘settings’ > install connection profile and follow instructions.
I believe the BTWiFi X hotspots are supposed to be more secure.
Hayseed
Message 6 of 21
Re: BT WiFi X
Thank you Paul_31, good answer, can now log into X. Always thought it was for business use as required a different log in.
Paul_31
Message 7 of 21
Re: BT WiFi X
You're welcome Smiley Happy
Rogercuthbert
Message 8 of 21
Re: BT WiFi X
I have the bt Wi-fi app ver 6.6.26 config ver 6.0
i can connect to BT Fon but not to bt Wi-fi x and there dones that seem to be an option to load a config profile, as previously mentioned, in this version of the app.
any ideas gratefully received.  I’ve used the same login manually when selecting wifix but it says wrong password.
Paul_31
Message 9 of 21
Re: BT WiFi X
@Rogercuthbert Hi, I'm using the same version of the app - the option to install the Profile is under (with the BT WiFi app launched) More (bottom RH corner of the screen)>Settings>Install Connection Profile
Rogercuthbert
Message 10 of 21
Re: BT WiFi X
Interesting. I looked there but all I have is
Play a sound....
Vibrate when a connect....
Notify me when I ......
Update login
About the app
That’s all
