wibbly
Message 1 of 6
BT WiFi (hotspot) credentials
Like many I have this service bundled with my Infinity package...
On Android, I'm trying to use a WISPr client (CoovAX) and want to be sure what credentials to use for BT WiFi
Are the credentials the ones I use to sign into "My BT", or something else? If something else, where do I go to find out what they are and/or reset them?
5 REPLIES 5
Distinguished Guru
Message 2 of 6
Re: BT WiFi (hotspot) credentials
http://www.productsandservices.bt.com/consumerProducts/displayTopic.do?topicId=30549
If not, I'll try again 🙂
wibbly
Message 3 of 6
Ok I found this
http://bt.custhelp.com/app/answers/detail/a_id/41199
So I ordered BEFORE SEPT 3, but have recontracted since...
Do I use my old @btinternet.com address or my BT ID credentials? Any will only one of these options work?
Distinguished Guru
Message 4 of 6
Probably the @btinternet.com like I do.
wibbly
Message 5 of 6
So the format BT/john.smith@johnsmith.com should work regardless, right?
Message 6 of 6
It depends if you are a new user to BT or have been with BT for a while.
If you are a new user you need to use your BTID and password The BTID needs to be a an email address to log onto BTWifi.
If you have been with BT for sometime you will have been given a primary email address when you first joined BT. It is this primary email address and password that you need to use.
See links for a bit mor information.
http://www.btwifi.co.uk/help/login-with-bt/
https://www.btwifi.co.uk/help/login-with-bt/connect-using-your-mobile-device.jsp
