Message 1 of 3
BT Wifi App says "not opted in"
Hello
I am having trouble trying to connect to BT WiFi when out and about.
When I enter my login details into the app it says "Not opted into BT Wi-Fi" although it has worked in the past.
My Smart Hub status screen says    BT WiFi status = Active
When I go to MyBT "Manage BT Wifi" and tick the agree to T&C box and click on Set Up Now after a delay it just comes back to the manage page again and just loops and goes round in circles. So I don't know were to go from here.
Is there anything I can try ?
Or is there a specific person/number to contact ?
2 REPLIES 2
Message 2 of 3
Re: BT Wifi App says "not opted in"
have you tried connecting to the BTWIFI on your own hub and see if that connects
Message 3 of 3
Although my hub says BT WiFi is active I do not see any BT WiFi connections listed under available networks on my computer or mobile.
Though as the set up/settings page through the MyBT webpage won't bring up any information I am unable to check any further.
Edit:
Just checking the hub log for the last time it did a reboot I see
00:00:39, 01 Jan.
wl0:WLAN has been deactivated (BTWifi-X) (band : 5GHz).
00:00:39, 01 Jan.
wl0:WLAN has been deactivated (BTWifi-with-FON) (band : 5GHz).
00:00:39, 01 Jan.
wl1:WLAN has been deactivated (BTWifi-X) (band : 2.4GHz).
00:00:39, 01 Jan.
wl1:WLAN has been deactivated (BTWifi-with-FON) (band : 2.4GHz).
So it would appear the status page is not correct.
