Icaras
Message 1 of 6
BT Wifi iOS profile
I have an iPhone 4s for my work phone. I have downloaded the BT Wifi app and entered my details.
However there is absolutely no option to install a connection profile in Help and Settings. On my personal iPhone I can see that option. Any ideas why it isn't showing up?
Basically I've got no way of installing the connection profile without it. Thanks.
Tags (1)
5 REPLIES 5
jjgraphics
Recognised Expert
Message 2 of 6
Re: BT Wifi iOS profile
Has some aspect of your work phone been hobbled by an IT department, by any chance?
Icaras
Message 3 of 6
It is a corporate iPhone yes. I'm wondering the same thing.
Message 4 of 6
If it is your IT Dept blocking the app's use you might still be able to log on without using the BTWifi app.
See Link
 http://www.btwifi.com/help/login-with-bt/connect-using-your-mobile-device.jsp#iphone
Once it has connected, open the BTWifi landing page and select the drop down "BT Broadband Customer" and enter your username and password.
Icaras
Message 5 of 6
Yes I know I can log in via the website at any point. BT should provide a link to install the profile though as the phone SHOULD let me as our corporate literature refers to a profile and I've managed to get it installed on the phone in the past.
Message 6 of 6
If you are using it as a business user and using a business log-on profile you may be better posting your problem on the BT Business Forum.
https://business.forums.bt.com/
