Message 1 of 5
BT Wifi reasking authorization too often
How do I configure BT Wifi (BT Broadband) to stop asking for me to login again every so often? Happens too frequently.
4 REPLIES 4
Message 2 of 5
Re: BT Wifi reasking authorization too often
does this happen when you are using BTWIFI maybe after a period
Message 3 of 5
Yes, happens sporadically though, its pretty random
Message 4 of 5
I have the same issue, but nobody on this forum appears to have an answer.
Message 5 of 5
If I remember correctly, BTWifi logs you out after two hours of use. You need to re log on if you wish to continue using it, until the next two hours has expired etc etc.
You will also be logged out automatically if the connection has not been used for 15 minutes.
It could also just be that the BTWifi hotspot signal you are logging onto is weak and as a result the signal gets dropped.
