Newuser6
Newbie
Message 1 of 3
BT Wifi-withpFON
Despite knowing that my Uder ID and passwork are correct, I am never able to log into BT Wifi via a BT hotspot.  Does anyone else have the same problem please?
2 REPLIES 2
Message 2 of 3
Re: BT Wifi-withpFON
just in case you are not aware, your have to use your BTID which has to be an email address.
Moderator
Moderator
Message 3 of 3
Hi @Newuser6  welcome to the forum and thanks for posting. The help page BT Wifi username and password will help you with this. If you are still having issues after this post back and let us know.
cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
