MHollick
Message 1 of 2
BT Yahoo calendar won't sync on iphone
Since changing the password on my BT Yahoo mail I'm unable to sync the calendar and contacts. Using the Yahoo selection pushes me through to a BT Yahoo webpage, while using the other tab allows access to mail and notes, but will not recognise calendar and contacts. Anyone else having this problem or can offer solution?
1 REPLY 1
Message 2 of 2
Re: BT Yahoo calendar won't sync on iphone
An idea......Are you using an email client on your pc?
Which iOS version are you using on the iPhone?
The iPhone on iOS 11 will only sync  with iTunes over wi-fi, or iCloud.....you can’t sync calendars and contacts over usb.
