davidgom
Message 1 of 8
BT cloud log in
Since the update am unable to acess Cloud from desktop as it will not recognise password.I can log in to MY Bt  no problem both passwords are the same.What is going on it is a complete shambles.
7 REPLIES 7
Moderator
Moderator
Message 2 of 8
Re: BT cloud log in
Hi @davidgom,
Have you bee able to get logged in since?
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”Kudos”
davidgom
Message 3 of 8
Re: BT cloud log in
Hi Daniel,No I haven't even uninstalled and re-installed but no joy
Moderator
Moderator
Message 4 of 8
Re: BT cloud log in
@davidgom Please use the 'click here to contact the mods' link in my forum profile to send in your details. You can find the link by clicking on my username.
Neil
Community ModeratorNeilO
Kudos”Kudos”
davidgom
Message 5 of 8
Re: BT cloud log in
Where is the URl?
Message 6 of 8
Re: BT cloud log in
davidgom
Message 7 of 8
Re: BT cloud log in
Thanks Keith
Waggle
Message 8 of 8
Re: BT cloud log in
I just downloaded the BT Cloud app to my iPad.
My attempts to log in are repeatedly rebuffed by this message:62DAE2C0-39B3-44B1-AF74-147730D5044E.pngError message repeatedly prevents log in.
Do you have any recommendations?
thanks,
