Karen50
Newbie
Message 1 of 2
BT cloud on mobile phone (android)
Good morning. I installed bt cloud on my mobile phone. The app seems to be constantly 'securing my content' because of this phone is running slow. I only have it set to save photos and contacts.
Getting annoyed now and wondering whether to delete app. Any help, gratefully received
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: BT cloud on mobile phone (android)
Hi @Karen50 Sorry you are having a problem with the Cloud service.
If this problem is still happening then please call the Cloud Helpdesk on 0800 500 3114 and they will be able to help you.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
