Moderator
Moderator
Message 11 of 18
Re: BT parental controls cannot be switched on - says unavailable
@Sheffwolf I'm so sorry about this, I'll be in touch shortly.
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Moderator
Moderator
Message 12 of 18
@Sheffwolf I called there but missed you, I'll be getting back on to the parental controls specialists now. You currently have the controls set to light so not all content will be blocked can you try changing the filter to moderate to see if that makes a difference?
Kudos”
Sheffwolf
Message 13 of 18
Tried that. Not blocking anything 😩
Moderator
Moderator
Message 14 of 18
@Sheffwolf thanks for confirming that, I'm getting back in touch with the parental controls specialists seeking further assistance with this fault.
Kudos”
Moderator
Moderator
Message 15 of 18
@Sheffwolf I see my colleague was chatting to you on Friday evening did they manage to get this sorted?
Kudos”
Sheffwolf
Message 16 of 18
Still not working.
My account has been riddled with faults from the very start and no-one seems able to fix it.
Moderator
Moderator
Message 17 of 18
@Sheffwolf Thanks for replying, I'll chase this up for you now.
Kudos”
Moderator
Moderator
Message 18 of 18
Hi @Sheffwolf I've been trying to reach you to make sure that everything is now sorted and ask if it's ok to close your complaint as resolved? I'd greatly appreciate it if you could get back to me and let me know.
Kudos”
