Strike999
Newbie
Message 1 of 6
BT parental controls
Hi, I wanted to change my BT parental controls filter but, in order to do this I needed to delete all my settings.
Thus, I did so and resultantly, I then enabled my parental controls to manage the settings, it said to wait as in the next 24 hours it would enable.
That was around a week ago, and it still says that, and the old parental blocked settings are still present as they still work.
I also restarted the hub, and it did nothing, I even installed a new hub, and nothing happened.
5 REPLIES 5
Moderator
Moderator
Message 2 of 6
Re: BT parental controls
Hi @Strike999
Sorry for the problems you have had when trying to change your parental controls.
I can help get this fixed for you. I've sent you a private message asking for the details we need to open an investigation.
Stuart
Community ModeratorStuartH
Show your appreciation!
Kudos”Kudos”
Moderator
Moderator
Message 3 of 6
Hi @Strike999
Thanks for sending us in your details.
I've raised this with the Parental Controls team today as soon as I have any updates I will be in contact with you.
Stuart
Kudos”Kudos”
Strike999
Newbie
Message 4 of 6
Hi,
Magically the problem is fixed, sorry for the hastle.
Many thanks
Eraj
Moderator
Moderator
Message 5 of 6
Hi @Strike999
Ah great news I'll close the issue down as resolved.
Post back should you need help again.
Stuart
Kudos”Kudos”
Moderator
Moderator
Message 6 of 6
Hi @Strike999,
No problem, thank you for taking the time to post back.
PaddyB
Community ModeratorPaddyB
Kudos”Kudos”
