Chris_Hibiscus
Message 1 of 2
BTCloud Dashboard Shows incorrect usage.
While adjusting the Backups to BTCloud on my PC and the Wife's I have noticed that unless you select something other than the Summary and then go back to the Summary an incorrect usage figure is shown.
It seems to remember the value when BTcloud dashboard was first loaded that day.
Think there may be a bug somewhere.....    Where do I report it?
Chris
1 REPLY 1
JoeeeeeeR
Message 2 of 2
Re: BTCloud Dashboard Shows incorrect usage.
Hi Chris,
btcloud.support@bt.com is listed as the developer contact address on Google Play / Apple App Store - I'd recommend dropping them an email.
I haven't noticed what you're describing, but I wouldn't be surprised if they hadn't designed the usage monitor to dynamically update, so it may not be a bug so much as a feature which doesn't exist.
