RKM
Message 1 of 2
BTCloud over-rides Auto-sleep
Has anyone else noticed that BTCloud over-rides the power settings in Windows10?
My power settings show the PC should go to sleep after 1hour without use and, until recently, that is what it did.
However, since the recent update to BTCloud it only seems to go to sleep if manually forced to.  If I stop BTCloud then it returns to normal operation, restart BTCloud and auto-sleep stops working.
Does anyone know how to force the power settings to take precedence over BTCloud?
1 REPLY 1
JoeeeeeeR
Message 2 of 2
Re: BTCloud over-rides Auto-sleep
Hi @RKM,
I haven't noticed this myself (my Windows10 laptop does go to sleep after the 30 minutes I've set it to). Have you checked if BT Cloud is doing anything while it's preventing your computer from sleeping? I guess it's possible that if it's actively backing up content / downloading content that this would prevent auto-sleep from happening?
