sekjeee17
Newbie
Message 1 of 10
BTWIFI-with-FON no internet connection!!!
Hello. When i try to connect to BT its say "no internet connection" and won't even bring up the homepage where you put in your username and password.
I bought bt-wifi for month, first 2 days it was okey, then it isn't worked for 2 days and showed no internet connection, at the day 3 it worked some 5 hours and again not working second day.
I search for some issue, but nothing found to fix my problem..
Sorry for bad english. Smiley Sad
9 REPLIES 9
Distinguished Guru
Message 2 of 10
Re: BTWIFI-with-FON no internet connection!!!
Hi and welcome to the forum.
Is it just the one wifi hotspot that you are having problems with? There may well be a problem with the hot spot route.
Try to get a connection using a different location.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 3 of 10
Same BTWiFi connection problem with me.
I purchased 1 month access, but connection with BTWiFi(London, Ilford IG3) is terrible.
I am trying all possible BT WiFi networks (screenshot is attached BTWiFi Network services), but rarely connection happens from the first 5 attempts.
Either it is no connection - timeout or after few min. I am getting message: «WiFi has the self-assigned IP address 169.х.х.х and will not be able to connect to the internet.»
Mac OS X 10.8.5 | iMac 2.5 GHz Intel Core i5 | 20 GB 1333 MHz DDR3
If I am lucky and get connected, service disconnects pretty soon – 15 min., 45 min.
Any tips, suggestions?
Cheers, Egils
Message 4 of 10
Hello,
I purchased BT 1 month access, but connection (London, Ilford IG3) is terrible.
I am trying all possible BT WiFi networks (screenshot is attached), BT WiFi Network but rarely connection happens from the first 5 attempts.
Tags (1)
Message 5 of 10
Delete any saved BT Wifi, Wifi with FON, etc connections.
Then rescan for the strongest one, and you may be lucky.
Some wireless management software gets confused when there are a number of connections saved, with the same SSID, even though the BSSID (MAC Address) is different.
This is a particular problem with some Android devices.
You could try some manual settings, typically.
IP address 10.188.245.2
Gateway 10.188.245.1
DNS 192.168.22.22 and 192.168.22.23
Message 6 of 10
Thanks! Deleting saved connections possibly helped. Time will show.
Manual settings were not working…
Cheers, Egils via BTWiFi-with-FON
Message 7 of 10
Its basically an issue with some wifi management software, and not a BT wifi issue. It gets confused when presented with multiple connections with the same name.
Its best to keep deleting any saved connections, each time you start a new session.
Manual settings were only an example, as the IP address may have already been assigned to a different user. You can always try higher IP addresses if you are really stuck.
KE
Newbie
Message 8 of 10
Every time I try to connect to the network it brings up the message 'unable to join the network "BTWiFI-with-FON" ' and I've been able to connect before
Message 9 of 10
is this connecting to your own BTWIFI or another person's BTWIFI when out and about?
Rachel939
Newbie
Message 10 of 10
My BT and myhusband's
