Rapmaster
Message 1 of 3
BTWIFI-with-FON opt out issues
Hi All, I have recently left BT but still use the SmartHub for wifi. It appears to still be broadcasting the BTWifi-with-FON signal. As I'm no longer a customer there seems no point to this so would like to opt-out of the service. I use my BTID to log into 'My BT' but cannot find the option to change my BTwifi status on this page: http://bt.custhelp.com/app/answers/detail/a_id/12958/~/how-do-i-opt-out-of-bt-wi-fi%3F Any help is gratefully received. Thanks, RM
2 REPLIES 2
licquorice
Message 2 of 3
Re: BTWIFI-with-FON opt out issues
Are you sure it is your hub broadcasting the signal and not another hub nearby?  If it definitely is your hub, try a factory reset by pressing the recessed button with a pin for about 20 seconds until the lights flash. In any case, there will be no internet connectivity via the BTwifi signal as you are not connected to the BT network.
Opting out will have no effect in any case as your hub would need to be connected to a BT service for the opt out to be delivered to it.
DavidM
Moderator
Moderator
Message 3 of 3
Good morning @Rapmaster and welcome to the community.
Thanks for posting about your opt out issue. @licquorice is spot on here with his advice. Try a full reset of the hub. It's unlilely to be your hub that's broadcasting and opting out won't have any affect if your not connected to a BT Service.
Cheers
David
