TimeLord16
Message 1 of 33
BTWiFi + FON
I cannot maintain a connection to BTWiFi + FON via my mobile (Samsung A3with a BT SIM) - it seems to connect briefly then drop out.
I can maintain a full WiFi connection with my BT hub or at a Premium Hotspot or other WiFi hubs (with password).
I can maintain a connection to BTWiFi + FON via my laptop from the same physical location.
Any ideas, please?
32 REPLIES 32
Message 2 of 33
Re: BTWiFi + FON
Are you using the BT Wifi app?
TimeLord16
Message 3 of 33
Re: BTWiFi + FON
Yes I am.
Also trying to connect through a WiFi Analyser app - same result.
TimeLord16
Message 4 of 33
Re: BTWiFi + FON
Correction - BT WiFi app only shows premium hotspots, so attempting connection thoough Settings - Connections - Wi-Fi
Message 5 of 33
Re: BTWiFi + FON
@TimeLord16 wrote:
Yes I am.
This can happen if you have multiple saved wireless settings for BT Wifi/FON.
Go into the wifi settings, and delete all instances of BT Wifi/FON, Openzone. Once you have done that, then just scan for the one you want to connect to, and use that.
TimeLord16
Message 6 of 33
Re: BTWiFi + FON
Thanks for reply.
Deleted lots of (redundant ) saved WiFi sites and left about 6 regular sites.
Problem still occurs.
I see "Connecting to...", "Connected to...", "Not Connected" all in about 3 secs.
Message 7 of 33
Re: BTWiFi + FON
@TimeLord16 wrote:
Thanks for reply.
Then its probably an issue with the hotspot itself, the owner`s home hub needs restarting.
You should really delete all of the saved ones, as some Android phones get confused with multiple SSIDs, even though the BSSIDs are different.
TimeLord16
Message 8 of 33
Re: BTWiFi + FON
Hi again - thanks for sticking with this so far.
The Hub I am trying to connect to via FON is my Home Hub.
I've powered it down then powered up again.
Still the same issue - cannot connect via my mobile 'phone (all saved sites are now deleted) but can connect from laptop.
Also had failures to connect to FON with other BT hub.
Message 9 of 33
Re: BTWiFi + FON
does the mobile 'see' the BTWIFI/FON network just won't connect?
TimeLord16
Message 10 of 33
Re: BTWiFi + FON
Yes.
Either through Settings/Connections/WiFi (seen as BTWifi-with-FON)
OR via WiFi Analyser app (seen as BTWifi-with-FON plus ISP details which are the same as the Home Hub details except for the last number).
No other BT Hubsare within range.
