Message 11 of 33
Re: BTWiFi + FON
Have you unticked 'automatically connect me to my home hub when in range' inthe BT wifi app settings?
TimeLord16
Message 12 of 33
Re: BTWiFi + FON
Just tried unticking "Automatically reconnect" - still will not connect to my FON.
Will try to connect to other BT Hubs later this moirning.
TimeLord16
Message 13 of 33
Re: BTWiFi + FON
OK, so to update the situation, it seems that I can connect to any other WiFi service (with password if required) but NOT to BTWiFi + FON.
Message 14 of 33
Re: BTWiFi + FON
Don't post the user name and password,  are you using your BTID and password to log on to BTWifi or some other username and password and if so is it an email address?
TimeLord16
Message 15 of 33
Re: BTWiFi + FON
Log details are email address & a password.
Spoken to BT Technical & have the following:-
1. You cannot connect to your own Home Hub FON service (even though I can connect to it by laptop) - so I've been wasting my time.
2. BT cannot guarantee connection to any other BT Hub + FON - it may be busy or not a strong signal.
3. Just because I can "see" a BTWiFi + FON signal does not guarantee a connection.
TimeLord16
Message 16 of 33
Re: BTWiFi + FON
To clkarify - using BT logon details.
Message 17 of 33
Re: BTWiFi + FON
There is one thing you can try, while at home, and that is to factory reset your home hub, if you have not already tried that.
That will remove any cached entries which may be preventing your mobile device MAC address being authenticated.
Then try connecting to your own BT WiFi/FON signal.
Have you also tried uninstalling then re-installing the BT Wifi app?
Message 18 of 33
Re: BTWiFi + FON
I can use my android phone and connect to my BTWIFI/Fon so I think they are fobbing you off
Message 19 of 33
Re: BTWiFi + FON
1. You cannot connect to your own Home Hub FON service (even though I can connect to it by laptop) - so I've been wasting my time. They are telling you complete rubbish
2. BT cannot guarantee connection to any other BT Hub + FON - it may be busy or not a strong signal. True
3. Just because I can "see" a BTWiFi + FON signal does not guarantee a connection. Also true as the hub concerned  may not be even connected to the internet.
TimeLord16
Message 20 of 33
Re: BTWiFi + FON
OK, so I have already uninstalled/re-installed the BT WiFi app - no difference.
Now I have done as you suggested - 1. Factory rest   2. Uninstall BT WiFi app again.
Everything back on line but exactly the same result - BTWiFi with FON connects then drops out after 2 secs.
