TimeLord16
Message 31 of 33
Re: BTWiFi + FON
I'll have a word with friends to see if a compatible size SIM is available yo borrow.
TimeLord16
Message 32 of 33
Re: BTWiFi + FON
OK, so I have identified the fault as phone-related, not SIM-related.
As suggested, I swapped SIMs with another phone that could connect to BTWiFi-with-FON on my Home Hub (with its own SIM).
After the swap -
a) the other phone + my SIM connected to the FON service
b) my phone + the other SIM connects/disconnects from the FON service, just as with my SIM fitted.
Conclusion:- my Samsung A3(2016) will not connect to the FON service (at least on my Home Hub).
Many thanks to all you people out there for your input.
TimeLord16
Message 33 of 33
Re: BTWiFi + FON
So a final post on this issue.
I booted the phone in 'safe mode'
I used settings/connections/WiFi to find BTWifi with FON - AND IT CONNECTED! Therefore the problem was with an app on the phone.
I deleted several apps until I was able to connect to BTWifi with FON, then reloaded the apps I wanted to keep.
Funny thing, though, the last 2apps I deleted that then let me find a FON connection I have reloaded and there is no problem.
Thaank you again for all your help.
