pwmoffat
Message 1 of 7
Backup folders
I am using Bt cloud to back up a number of devices.
separate users on a pc have separate folders.
ipads and iPhones seem to have been set up in a sub folder in a folder called BT Cloud
We have  2 iPads each has a separate backup sub folder eg “johns iPad”  “Ann’s iPad”
these seem to map the name of the iPad.
we have 2 iPhones each with different names eg “johns iPhone” “Ann’s iPhone”
for some reason they have been backed up in one directory called “iPhone”
i would like them backed up in different sub-directories how can I do this.?
6 REPLIES 6
Moderator
Moderator
Message 2 of 7
Re: Multiple iPhone backup
Hi @pwmoffat Sorry you are having an issue with the BT Cloud.
Please contact the Cloud helpdesk on 0800 500 3114 as they will be best placed to help you with this. They are open 9am to 9pm Mon - Fri and 9am to 6.30pm Sat and Sun.
Cheers
John
pwmoffat
Message 3 of 7
Hi John
Thanks will do
Paul
pwmoffat
Message 4 of 7
Hi
thanks for the advice .. they helped me solve the issue
notozman
Message 5 of 7
Hi, can you pls share the solution to this one - thanks.
Moderator
Moderator
Message 6 of 7
Hi @notozman  and welcome back,
Thanks for posting again. This thread is a few months old and was resolved. Are you having similar problems to @pwmoffat ? Have you tried contacting the Cloud helpdesk on 0800 500 3114  as advised by @JohnC2 ?
Cheers
David
pwmoffat
Message 7 of 7
Hi sorry to take so long to get back. I can’t really remember the solution but I spoke to a chap called Kedar in Colcuttar , on the help line suggested . He was excellent and talked me through a solution. This included uninstalling Bt cloud and  reinstalling which seemed to work
