loushaddick
Message 1 of 4
Blocking you tube app on the hub?
I want to block You Tube access from the hub level but on n parental controls you can only block a website not an app so it doesn't stop usage of the You Tube app. Could anyone tell me if it is possible to block an app please?
3 REPLIES 3
AndyCoffin
Message 2 of 4
Re: Blocking you tube app on the hub?
Not possible from the hub but can be done via 3erd party dns providers, i found a guide for opendns here.....
http://www.unwrittens.com/how-to-block-youtube-in-the-home-network/
Message 3 of 4
i have successfully blocked YouTube by adding the following urls to the blocked list.
youtube.com
only issue is that if you allow for a short time by turning off parental controls it obviously removes all other safeguards.
it would be a great feature if you could turn off blocked sites only temporarily.
glentress
Message 4 of 4
Hi. you have to use several addresses to block across app etc.
www.youtube.com
  • googlevideo.com
  • ytimg.com
  • youtu.be
  • apis.google.com
  • gstatic.com
There maybe more since I last updated the list, because google own youtube now theye push out under various address.
Good luck as I know your pain.
