Demby
Message 1 of 3
Bt Cloud
Hi. I have downloaded the Bt cloud app to my iphone and PC. My phone shows that I have 1.2 gb of music, which is visible and accessible. My PC simply tells me that I have music stored but no indication of what it is and how to access it. Any ideas please
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: Bt Cloud
Hi @Demby thanks for posting. I found this help article on how you can back up your music and listen to it on the go using BT Cloud. I hope it helps.
Demby
Message 3 of 3
Re: Bt Cloud
thank you for your help
