petereng
Message 1 of 3
Bt Net protect and anti virus software
Does anybody know if this product can be used on an iPad and iPhone?
2 REPLIES 2
JoeeeeeeR
Message 2 of 3
Re: Bt Net protect and anti virus software
It can't be - it's just been realised for Android. Apple tend to allow 'antivirus' products on iOS as it gives the impression their products are susecptable to viruses, so I suspect this is something to do with why there isn't an iOS verison (more detail on that here: http://www.theregister.co.uk/2015/03/24/ios_anti_malware_confusion/
adie1
Message 3 of 3
I suggest you do your research first before marking a question as solved as i have the bt net protect software running on an apple iphone 6s and an iphone 7. it has been designed to run on android and ios operating systems for a while and the bt net protect software is a mirror of mcafee antivirus software.
