Tarnbrick
Message 1 of 5
Bt cloud
I have a problem with BT Cloud.  On the cloud website when I ask to view a stored document it displays a dark grey image with no text and the following error
PDF.js  v1.0.907 (build: e9072ac)  Message:  Invalid PDF Structure
If I ask to download the document to my PC it displays correctly with text.
Can't understand why this happens, I have been using BT Cloud for years without too much trouble.
If this post is not in the correct part of the Community can someone advise where it should be posted?
Thank you.
4 REPLIES 4
Tarnbrick
Message 2 of 5
Re: Bt cloud
Forgot to add that this is a Microsoft Word document
Moderator
Moderator
Message 3 of 5
Re: Bt cloud
Hi Tarnbrick, Sorry that you are getting this error. You would be best to contact the Cloud helpdesk on 0800 500 3114 (9am-9pm Mon-Fri and 9-6.30pm Sat and Sun).
Cheers
John
Tarnbrick
Message 4 of 5
Re: Bt cloud
Hi John
Thanks for that.  I will give them a ring - I hope it's in the UK!!!
Tarnbrick
Message 5 of 5
Re: Bt cloud
Hi John
As you suggested I have rung the cloud help desk.  They have given the query a complaint reference number and said that I will receive a call from India.  Previous experience of this has always ended in failure. Lovely people, very patient and polite but can never solve the problem.
I have found that this error was queried on this community forum in 2016 and I have messaged the poster to ask him if he ever got a solution.
Also if you run a Google check on the error details it would appear that it crops up everwhere, there are umpteen pages about it but unfortunately no solution.
John.
