Message 1 of 15
Bt dual band wi-si extender 750
Hi all i was wondering if anyone can help me with this I got this extender today to reach to the back bedroom as the signal there is poor, I set it up near the router like suggested had the lights go on and then pressed the wps button on router and then on the extender it all set up fine, just red light saying to close to router which i expected there so i moved it to the landing which is halfway between router and the room with bad signal.
When the extender is powered on now it does nothing and the WPS light just stays on and have a blue light on the power but nothing else to say good range or anything and cant connect to the extender I tried to reset it so I could start again it said to make sure extender is plugged in and press down the reset button I did this and nothing has changed
Any help or do you think its a faulty one as I cant seem to get it to reset
Thank you
Angela
14 REPLIES 14
Message 2 of 15
Re: Bt dual band wi-si extender 750
also forgot to add we have the bt home hub 5
Moderator
Moderator
Message 3 of 15
@Angela230787 Welcome to the forum and thanks for posting. After pressing the reset button did you move the extender closer to the hub and follow the set up process again?
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
Message 4 of 15
Hi yes I did and as soon as its plugged in all i get is the solid power light and solid wps light which says it should go off after 30secs but there is no light to say good signal or anything
also after pressing the reset button it didnt do the flashing two red lights like it did when i first plugged it in
Message 5 of 15
it does show on wireless networks but cant connect to it and it says Bt wifi-X not the EXT750like the instrusctions say if that means anything not sure if faulty or something im doing
Moderator
Moderator
Message 6 of 15
@Angela230787 It sounds like it's faulty if the reset button isn't working. The wi-fi extender 750 help desk will be able to give you more advice on this.
If your product is within warranty:
By phone: 0808 100 6116
Monday to Friday 9.00am to 5.30pm
Saturday 9.00am to 2.00pm
By email: btconnectedhome@bt.com
Kudos”Kudos”
Message 7 of 15
when u press the reset button how do you know if its done it would it go back to all the lights flashing the red ones waiting for you to set it up?
Moderator
Moderator
Message 8 of 15
@Angela230787 I'm afraid the user guide doesn't mention that, I presume it should go back to the default settings like it was prior to you setting it up.
1. Make sure the extender is plugged in and switched on.
2. Press the Reset button for 1 second to restore factory default settings.
If that's not working I would recommend you contact the helpdesk using the contact details I posted earlier.
Kudos”Kudos”
Message 9 of 15
ok thank you as I only got it today though I may go back to the shop tomorrow and see if they will replace it if not will have to phone them
Moderator
Moderator
Message 10 of 15
@Angela230787 I'm really sorry about that. Post back and let us know how you get on.
Kudos”Kudos”
