Showing results forย
Search instead forย
Did you mean:ย
Message 11 of 15
Re: Bt dual band wi-si extender 750
will do now for nice glass of wine and forget about the wasted hours ๐Ÿ˜„ and then think about the argument with the place tomorrow they are not good for returns normally
Message 12 of 15
This would have been a better choice.
http://www.shop.bt.com/products/bt-mini-wi-fi-home-hotspot-600-kit-084288-BVFF.html
Wifi extenders (repeaters) often give problems.
Message 13 of 15
that would have been better? sorry im ok with like graohics cards and building pcs etc but not wifi so sorry for being dumb i just thought the higher number the better i saw the 600 dual pack but just thought 750 would be better
Message 14 of 15
Just update I took the extender back and they did have one left in stock but I opted to change and get the one mentioned in this post the 600 plugged it in at home all working fine and excellent signal now in back room which use to sometimes get one bar or mostly none at all ๐Ÿ™‚
Message 15 of 15
I am pleased that its sorted, the hotspot 600 kit is a very good product.
