Exlagerer
Message 1 of 9
Bt tv app
I'm looking at changing my TV provider and was looking for a bit more info on the bt tv app
Is it possible to transfer your recordings from your box to the app to watch offline?
Tags (1)
8 REPLIES 8
Message 2 of 9
Re: Bt tv app
No.
Exlagerer
Message 3 of 9
Re: Bt tv app
Thanks,  do you think it's something that they will introduce in the future as other tv providers offer this service?
Message 4 of 9
Re: Bt tv app
As the recordings are stored on the box, and cannot be transferred for copyright reasons, then I doubt that BT will even consider it.
Exlagerer
Message 5 of 9
Re: Bt tv app
I'm surprised at that as if I've read it correctly you can do this if you have EE tv.
Moderator
Moderator
Message 6 of 9
Re: Bt tv app
@Exlagerer This link explains what you can do with the BT TV app
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
Exlagerer
Message 7 of 9
Re: Bt tv app
Many thanks n
Distinguished Guru
Distinguished Guru
Message 8 of 9
Re: Bt tv app
That was the EE Recordings to Go which they did offer for a few months however they (EE) withdrew that feature in June
following discussions with their content rights-holders.
Exlagerer
Message 9 of 9
Re: Bt tv app
Ah ok that explains it
