Madpartyboy
Message 1 of 2
Bt wifi overseas
Hi
I am travelling to the states shortly was wondering how easy it was to connect to the free AT&T hotspots in the u.s
it says bt have a partnership with them just wondering if anyone has used it over there
I know they have the fon hotspots but doing a search their does not to be many showing up
also when you connect to the AT&T hotspot do you log in using your bt account
many thanks
1 REPLY 1
Message 2 of 2
Re: Bt wifi overseas
Its possible that its simply a roaming agreement with BTOpenzone, in which case BT Broadband customers will not be able to use them for free.
Its the same in the UK, roaming arrangements do not allow BT Broadband users.
