BigChris1
Newbie
Message 1 of 4
Can I Change BT Sync Folder Location?
Hi all,
first time poster here, I hope someone can help. I recently got a free 500GB boost to my BT Cloud, so I thought I would take advantage of it as my DropBox account free 50GB comes to an end soon. I need to move the sync folder from the windows drive, as it is partitioned to 40GB for the windows installation alone and only has 10GB free.
Is this something that can be done? I need this sync folder to be on a different drive, in order to use my 500GB allowance...
Any help/advice greatly appreciated!
3 REPLIES 3
22pilgrim
Message 2 of 4
Re: Can I Change BT Sync Folder Location?
I have mine on an external drive. I use Mac, but it should be the same.
BigChris1
Newbie
Message 3 of 4
Thanks for the reply, how did you change the location of the sync folder?
Many Thanks
22pilgrim
Message 4 of 4
I just copied and pasted the sync folder to the new drive
