Message 11 of 29
Re: Can I get my Smart Hub to stop spewing radiation please?
Carlusha - That's a really helpful suggestion. I'll look into it. Many thanks.
Message 12 of 29
Re: BT Wifi-X opt out
licquorice - I was more than happy with my old hub but because it was actually impossible to switch off the shared WiFi, I requested to change to the latest version because it had the facility to do so, and for no other reason. So yeah, it may well be part and parcel of the default setup, which I was happy to agree to........ however.......
Message 13 of 29
The TP Link Td-W9970 router is about £40 at Argos and £33 at Amazon. The wifi can be permanently turned off.
Message 14 of 29
Be aware that placing the hub in a bag could cause over heating issues.
Message 15 of 29
There is no difference in whichever hub you use in respect of turning off wifi. The turn off needs to be done at the network level as well as your hub in order to prevent you accessing the signal whilst out and about but not transmitting at home, hence it can't be turned off locally on the hub.
Message 16 of 29
I was told by tech support that my old hub ( Home Hub 3.0 ) couldn't be turned off at the network level. Of course, I was able to turn off the WiFi acccess with respect to my Local Network but the RF meter confirmed that WiFi activity was still occuring. I spent quite a long time talking to tech support trying to disable WiFi completely on my old hub but eventually they conceded that it could not be done. I managed to get this done on another hub ( BT Smart Hub 6 ) and was successful after requesting this via phone from tech support.
Message 17 of 29
To avoid confusion when using the generic term "wifi" can we refer to the "normal" signal emit by the hub as the "wireless" signal and  BTWifi with Fon or BTWifi X by their names.
Message 18 of 29
For the sake of a few quid I suggest you buy the router mentioned.
ALL wifi on that device can be turned off permanently. Even if you opt out of BT wifi with Fon, it is apparent from other posters that it can be re-enabled with firmware updates to your hub and need opting out again.
Message 19 of 29
Fully agree with licquorice.
Message 20 of 29
Many thanks for the advice to you both.
I'll buy the hub suggested.
