Message 1 of 2
Can connect to the BT wifi hotspot, but I can't access the BT hotspot website to login
I bought a 1 day pass with the BT Wi-Fi hotspot. I logged into my account and was able to surf the net just fine.
However, now it doesn't work. I can still connect to the wifi hotspot just fine, but I can't access the BT site so I can login and continue surfing.
Is this a common problem? I've tried multiple devices and the same problem still happens.
Appreciate any explanations or pointers. Thanks.
1 REPLY 1
Message 2 of 2
Re: Can connect to the BT wifi hotspot, but I can't access the BT hotspot website to login
To get to the BTWifi landing page try typing  https://www.btwifi.com:8443 into your browser.
See link
How do I use BT Wi-fi, find hotspots and get online? | BT Help
If that doesn't help and if you are still within the day that you activated the pass you should call the BTWifi Help line  0800 022 3322
