Distinguished Guru
Distinguished Guru
Message 11 of 11
Re: Can not see bt wifi minutes
@conrad wrote:
Have had a look through the site and can't find anything referring to 10,000 minutes anymore. It is referred to as unlimited and when you look at this page  http://www.productsandservices.bt.com/consumerProducts/displayTopic.do?topicId=30549 and then the legal link http://www.productsandservices.bt.com/consumerProducts/displayTopic.do?topicId=35807 there is no mention of any limit now.
I've had another look at this and also find that nearly all the documentation, by omission, suggests that the limit no longer applies to BT Broadband customers. The only exception I could find is in the legal stuff at the bottom of your first link; that still refers to a fair use policy, though as you say this is not present in the further link to terms and conditions.
That's all a bit negative though, so I'm asking the mods to post confirmation (or otherwise) here so that we can be sure about advice to any future enquirers.
