englishbullterrier
Message 1 of 2
Can someone help me please on device selection on Cloud ?
Hello all,
I'm using BT Clould to backup 2 separate devices, both microsoft based laptops.
Can somehelp me to select either one of them or does the backed up data all go into one "device" cloud ?
I can find no option how  to select each device individually.
Many thanks...........ebt
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Can someone help me please on device selection on Cloud ?
Hi @englishbullterrier,
If you take a look at How to upload and backup with BT Cloud, you'll find some more information about BT Cloud.
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
