MrAlien
Message 11 of 12
Re: Can't Turn On Parental Controls
It all seems to be working correctly now. I can also change the filter level and save the changes correctly, and I can also turn Parental Controls off and back on again successfully.
So to recap, I used the red 'Delete Settings' button (that appears when PC are turned off), deleted any settings I had and then I could re-enable Parental Controls and change filter level etc quite happily.
Thanks,
Keith
Moderator
Moderator
Message 12 of 12
@MrAlien That's great I'm glad your parental controls are working for you now. I'll leave a message with @DanielS to let him know.
