angeljs
Message 1 of 4
Can't add new blocked sites to parental controls
I'm trying to add a site to my blocked list, but when I try I get the message:
There was an error when saving the data
The site is not already on the list, so I'm not sure what the issue could be.
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Can't add new blocked sites to parental controls
Hi @angeljs
Thanks for your post and welcome back!
Sorry for the problems you're having adding blocked sites to Parental Controls.  Have a look at this and let me know how you get on:  Parental Controls problems
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
angeljs
Message 3 of 4
No, I've already perused the FAQ's. Some sites can be added, and some can't. This is the one I've been trying to add:
www.croxyproxy.com
Moderator
Moderator
Message 4 of 4
www.croxyproxy.com
Hi @angeljs
Thanks for posting back!
Can I just get you to confirm that you've had a look at this?
If you have and you're still having the same problem you can get in touch with us and we'll check this out.  I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Cheers,
Robbie
Kudos”Kudos”
