keitht8351
Message 1 of 10
Can't connect to BT Wifi Hotspots
I'm a BT Infinity customer but can't connect to Wifi hotspots. I have tried using both my BT ID and BT e-mail address without success. I know the password is correct because I have just installed My BT on my Android phone and that works fine. I have deleted and re-installed the BT Wi-fi app but still no success. Any suggestions to fix this would be appreciated.
9 REPLIES 9
V_Meldrew
Recognised Expert
Message 2 of 10
Re: Can't connect to BT Wifi Hotspots
Did you opt-out of BT wireless (BTWiFi-with-Fon)? If you did you wont be able to connect to hotspots
keitht8351
Message 3 of 10
No. I haven't opted out of anything, not knowingly anyway. Any way I can check?
Message 4 of 10
@keitht8351
Look on MyBT try this guide Opt in or out of BT Wifi using MyBT
Message 5 of 10
keitht8351
Message 6 of 10
Thanks for the help. Definitely not opted out of Wifi. BT Wifi has a green tick against it and if I scroll down, one of the options is Opt out of BT Wifi, so I am still 'active' on the system.
V_Meldrew
Recognised Expert
Message 7 of 10
Try updating your login details within the BT wifi App, maybe it didn't take for some reason
Message 8 of 10
You don't need to use the app. Just connect to the btwifi signal and open a browser, can you log in that way?
keitht8351
Message 9 of 10
When a BT Wifi signal is available I try to connect to it 'manually' i.e. without the app. I've tried by using both my BT ID and my primary e-mail address and both fail to connect. I'm not convinced that it's even attempting to connect as the 'fail to connect' message is virtually instantaneous when I hit 'login'. What I'll try though is deleting the BT Wifi app in case there is something going wrong there and interfering with the connection process. I can't do that before tomorrow but will let you all know the outcome. Thanks again for all the attempts to help solve the problem.
keitht8351
Message 10 of 10
I said I'd report back, but I'm honestly none the wiser as to what happened. I tried connecting to a hotspot today and it connected immediately. I haven't changed any settings and haven't uninstalled anything either. I don't know if there has been an update to anything which might have made it work now. I'm not going to dig too deep in order to find the answer incase it screws things up again. I'll just be thankful that it's now working again.
