JosephH1
Message 1 of 5
Cannot opt out of BT Wi-Fi anymore
Checked the connection status after firmware update and noticed the BT WiFi Is activated, which I previously opted out. Went on MyBT and couldn’t find the option to opt out anymore. The opt in/out setting used to be under Broadband extra or something but doesn’t seem to exist now.
does anyone have any clues how to opt out online?
Tags (1)
4 REPLIES 4
smithyg
Message 2 of 5
Re: Cannot opt out of BT Wi-Fi anymore
I believe I have found it under My BT / Your Products / BT WiFi
Regards, Graham.
JosephH1
Message 3 of 5
Thanks Graham.
That’s what I got when I previously opted out of BT WiFi as well. Now when I go to check under my products/broadband, all I have are the Broadband Security extras and nothing to do with opting in/out of BT WiFi.
Anyway, I’ve just checked the connection status on the hub and noticed it is now switched off! Probably just a slow “pickup” from the system after the weekend’s firmware update...
Thanks again!
PaddyB
Moderator
Moderator
Message 4 of 5
Hi @JosephH1,
Thank you for posting. The default setting on the Hub is to have BT WiFi as opted in. Whenever there is a firmware update or a factory reset done on the Hub. The hub will show that BT Wifi is active and opted in. This will normally change back to opted out in a few days.
PaddyB
JosephH1
Message 5 of 5
It’s good to know for the future updates.
Thanks PaddyB
