Message 1 of 8
Cannot update to Norton from Macafee
When I click the update panel in my account, I get a server error. My mac OS is Catalina 10.15.7 is this a problem?
Tags (1)
7 REPLIES 7
Message 2 of 8
Re: Cannot update to Norton from Macafee
Hi @chris661, welcome back, and sorry you're having trouble changing over to Norton.
The list of what devices you can install Norton on advises that the Current and previous two versions of Mac OS are supported.
That would mean you would need to be on either of these versions which should be ok i believe:
OS 10.15: Catalina - 2019
OS 11: Big Sur - 2020
OS 12: Monterey - 2021
The server error usually indicates that you're not using the BTID or have not claimed the Account Holder Status on the BTID. Please check this and post back to let us know how you get on.
Cheers
John
Message 3 of 8
I do have account holder status.
Message 4 of 8
Hi @chris661, thanks for checking that for me. I've just one more thing I can think of. Do you have more than 1 account on your BTID?
Cheers
John
Message 5 of 8
No, but I do use same ID for my email account
Message 6 of 8
Hi @chris661, that shouldn't cause any error. I've sent you a Private Message so you can get in touch with the Mod team and we'll be happy to help your further with this.
Cheers
John
Message 7 of 8
In case this was the error, I changed my password for My BT account, and it worked !
I now have Norton installed
Message 8 of 8
Hi @chris661, thanks for the update and info on how you fixed this.
Cheers
John
