Message 1 of 3
Change to BT Norton ?
Hi there !
If I change my current security provider to BT Norton. Which Norton Product & Version do I get ?
2 REPLIES 2
Message 2 of 3
Re: Change to BT Norton ?
I don’t know what version. If you have iPhones/iPads they aren’t supported.
Message 3 of 3
Where to find a Norton Product Info.
Have a punt around the UI, until you find the 'ABOUT' link; the info is there.
