karaokek
Message 1 of 6
Cloud Bulk Uploader Plugin
Using Firefox as browser when trying to upload folder using the bulk uploader option I get this message
a plugin is need to dispaly this content
any ideas where i can get the plugin?
I do not have this problem with Internet Explorer.
5 REPLIES 5
Moderator
Moderator
Message 2 of 6
Re: Cloud Bulk Uploader Plugin
Hi @karaokek Thanks for your post about the BT Cloud. Did you have any luck getting the plugin?
If not we will be happy to help you with this if you send us your details. You can contact us by clicking on my user name and selecting contact the mods.
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
drone1
Message 3 of 6
Dear John
Would it be possible just to name the plug-in, for people searching the website in the future?
I get the message 'a plugin is needed to display this content' when I try to upload a folder from the web application. Not much help.
Mac OS 10.11.6, Firefox.
graystreet
Message 4 of 6
It seems to be made by a Company called Aurigma. You need to have JAVA installed for it to find it automatically so that rules it out for me.
It's still limited to a file size limit which seems to be around 500 MB.
drone1
Message 5 of 6
I'm still getting the 'missing plug-in' message when trying to upload a folder from the BT Cloud website.
This strategy works perfectly when I use Amazon drive.
Would anyone know the name of the missing BT Cloud plug-in? Someone suggested 'Aurigma' but I'm still stumped.
graystreet
Message 6 of 6
You need to have Java installed and enabled in your browser for it to work, once Java is enabled then the plugin runs automatically. Or at least it does on mine...
