r1sean
Message 1 of 2
Cloud Help
I installed BT cloud last night and it spent all night uploading around 38Gb into it then I logged out and went out this morning when I came home lunch time I opened it up and it says its transfering 22,000 files again am I doing something wrong as it's crazy the files were all their this morning and now they seam to be trying to upload again????
R1Sean
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Cloud Help
Hi r1sean,
Are you using the process explained in this link BT Cloud to upload your files? Let us know if you need any further help.
Cheers
Neil
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
