JohnC1
Message 1 of 1
Cloud storage
Just started using the Cloud storage and have two issues which I'd like some advice about
1) Photos. When I upload it seems to do so in reverse order from that intended. Not sure why but I've got (for instance) a set of wedding photos that start with the happy couple going off on a honeymoon and finish with the bride arriving at the church! Can I easily get them back in corrct sequence. I've found the manage album option but this means moving each one manually and at 200+ photos that seems unnecessarily laborious
2) Music. I've uploaded my music library but some files won't play. Seems to primarily be ones purchased from Itunes. I'm assuming they are "protected" in some way so is there any way of removing this? Even if I can't play them can I still retrieve them from the Cloud later if the original file is deleted?
