Colly-FC
Message 21 of 23
Re: Connect to and Extend BT Wifi / BT FON ?
Similar problem to the one I have. Windows phone and iPad did work fine and then would not connect.
Have you tried to reboot your router? I assume you are using HH5,this has worked for me but does not seem to last that long before it needs to be rebooted again.
bloooor
Message 22 of 23
Is there anyway i could also get the guide for turning an extender into a repeater? Thanks in advance
Kind regards,
Adam
Madmatt
Message 23 of 23
Keith_Beddoe any chance I pick your brains about this as you're link doesn't seem to work and nor does your site
Thanks matt
