Message 1 of 4
Connecting to a by hotspot, log in page does not come up
Hi, I have just moved house and I am trying to connect to a "bt with fon" hotspot, which I have done the last time I moved house. But when I connect to the hotspot then attempt to open the Internet it does not take me to the log in page, it just says "no internet". I have tried it on edge, chrome and Internet explorer on both of my laptops and no joy. Please help!
3 REPLIES 3
Message 2 of 4
Re: Connecting to a by hotspot, log in page does not come up
As the BTFON is probably being broadcast from a home hub the hub probably needs reset but there is nothing BT can do about that as up to the owner of hub
Message 3 of 4
Update....I have connected to the hotspot with my iPhone 4 but it still doesn't work with my laptops. It disnt work at first so I went into settings and change an option then when I opened safari it took me to the log in page. If the bt hotspot needs resetting why does it work on my iPhone?
Moderator
Moderator
Message 4 of 4
Hi @Rosasilvestre421 I found this info on the BT WiFi help pages
Note: if you accidentally lose the web browser window confirming your connection, type https://www.btopenzone.com:8443/home or https://www.btopenzone.com:8443/status into your address bar and the window will reappear.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
