Message 1 of 4
Connection timeout and BTFON connection problems
Hi
I've had Bt Internet for a few months now and right from the start have encountered intermittent problems when trying to connect my iPhone and MacBook Pro to the Home Hub 3. Sometimes they will connect perfectly on the first attempt. Other times they will pause for a spell and then give an error message along the lines of "Cannot Connect. Connection timeout". If I have the patience, fiddling about with turning the device's Wifi off and on a few times, rebooting the homehub or simply just trying to connect over and over again will result in the connection finally being made. Once connected, there are no issues with dropouts or speed, it's just making the initial connection that's proving to be a real pain.
Similarly, when trying to connect to BTFON or BTOpenzone whilst at home (usually when getting frustrated at not managing to connect to my homehub's signal), which I assume are being transmitted via my own homehub, sometimes it sonnect, but more often than not, the browser just sits with a blank screen whilst trying to connect to the btopenzone page. I've found that rebooting the homehub will sometimes cure this problem, but I have no idea why and it's very frustrating.
Any help or advice would be much appreciated.
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Connection timeout and BTFON connection problems
Hi Douglasgrant,
Welcome to the forum and thanks for posting. I can take a look at this for you if you wish. Drop me an email with your details. You’ll find the “contact us” form in the about me section of my profile.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Suggy
Newbie
Message 3 of 4
Hi
I am having the same very annoying problem re time out, connections dropping, having to use openzone when my 'normal' security protection just stops...........
Any help gratefully received
Cheers
Suggy
drewr2010
Newbie
Message 4 of 4
See? I guess they never got back to you cause they know there's a major fault with their apparent great services. I pay £15 for 5 days, and in reality I get 1 day's worth of connection time cause I can't connect!
