bagginsatsea
Message 1 of 4
Dongle information on MyBT account page gone missing
I had not used mt broadband BT dongle for three months and then made a £10 payment but the facility to convert the tenner to a data bundle has disappeared of MyAccount page.
Been given the run arround for three weeks now but no joy in getting it re-established.
Tryed re-regestering the dongle as advised only to be told 'already regestered.
I know....................I know!
Any help please - I know from other postings I am not alone.
Tags (1)
3 REPLIES 3
Message 2 of 4
Re: Dongle information on MyBT account page gone missing
Hello Bagginsatsea and welcome to the forums,
After logging in, under the My BT page:
https://www.bt.com/appsconsumeraccount/find.do?userLoginEventSuccess=true
On the right hand side above the picture of the MacBook laptop and below the My BT tab is a drop down menu with "Switch account" written next to it. *Hopefully* you will have two options in the dropdown - one that will be your normal landline account and one will be your Mobile dongle account.
Hope this helps,
bagginsatsea
Message 3 of 4
Thanks for prompt assist but only my BT account number shows there - no drop-down menu.
bagginsatsea
Message 4 of 4
Tommybobbins.
You solved it - thanks very much.
The pre-pay dongle was registered to a bt account that was duplicated and on the old log-in the drop-down menu appeared.
Thanks very much indeed
