Message 1 of 5
EE payg and BT mobile app
I have two mobile both EE payg. I have BT BB Smarthub (latest).
Can I use the BT app on my mobiles to access the internet free when away from home as part of my package?
Thanks.
4 REPLIES 4
Message 2 of 5
Re: EE payg and BT mobile app
as long as you are opted in to BTWIFI with your broadband then using your BTID should login on your mobiles
Message 3 of 5
I have looked on Google Play for the App but it is not there (as BT-Wi-fi radio logo. Just a bunch of other BT stuff. Does that mean that the logo has changed or won't work on an EE mobile.
Message 4 of 5
you don't need the app to login to BTWIFI you can do that using a browser
Message 5 of 5
Yes thanks, I know but App would be easier.
